MMM "cushion lift" adjustment: How often?
   / MMM "cushion lift" adjustment: How often? #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
MMM \"cushion lift\" adjustment: How often?
Dragged the MMM out of the shed last night. My bed time reading was reviewing the owner's manual. Need to clean it up, grease it and sharpen the blades. I know, I should have done it in the fall, but the snow started a little early.
Anyway, there is a passage in the "assembly" section that describes adjusting the cushion lift. Is this some thing that needs to be done periodically, or is it a set it & forget it, unless the deck insn't cutting evenly?
Re: MMM \"cushion lift\" adjustment: How often?
Judging by the 47 views & no replies that I can assume "If it ain't broke, don't fix it". /forums/images/graemlins/tongue.gif
   / MMM "cushion lift" adjustment: How often? #3
Hazmat,
I hate it when a message gets no replies. So, I'll respond:
I don't know what cushion lift is. Sorry I could not be of more assistance.
bmac,
Don't sweat it. The "cushion lift" is basically a couple springs & tie rods that allow the three point hitch to carry most of the weight of the MMM. The New Hollands are a hybrid floating deck / ground contact setup.
   / MMM "cushion lift" adjustment: How often? #5
Hazmat,
Thanks for the explanation. My reply was a feeble attempt at humor. Maybe I should have included a smiley face. /forums/images/graemlins/smile.gif
   / MMM "cushion lift" adjustment: How often? #6
I just put mine back on and didn't adjust anything.
If it is out of level use the crank on the right lift arm to level it.
Just reset the handle stop to the correct lower position.
I had my mower off weekly last year and just pin on and go.
I think the MMM group is rather small.
   / MMM "cushion lift" adjustment: How often? #7
Hazmzt,
Sorry about the response. I'm working in Mexico right now and can't always get on line.
I have had a 914A mmm for three years - had it off multiple times each season, and have never adjusted the "cushion Lift". It just keeps on cutting, smooth, even, and without complaints. Keeping it lubed along the 25 hr guideline is important, and keeps me and big blue happy!
Thanks Boomerboy & Hoeman. I guess I'll leave well enough alone.
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2001 Diamond 20' Fuel Trailer, VIN: 5FWFS18241R000024, Tandem Axle, Asset# 27 (A59076)
2001 Diamond 20'...
2015 CHEVROLET CRUZE (A56859)
2015 CHEVROLET...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
