Buying Advice MK5000
   / MK5000 #1
Mikeydpl
Cornwall. England
Mitsubishi MT 180D
Hi
Anyone on here have or had one of the above Tractor, about to get one and would appreciate any comments
Mike
   / MK5000 #2
It looks like our MX5000, MX5100, etc. If it is, it's one of the best tractors Kubota every made and is wildly popular around here. I don't know of any problems and sure don't have any with mine.
   / MK5000 #3
Great tractors. Load tires, AND add wheel weights if you get an fel... they are way light in the butt...
   / MK5000
Hi
Thanks for the reply,not sure what the difference is between the MX and MK but as you said they look the same, thanks again sounds like I have made a good decision
   / MK5000
Yes getting a FEL with it, will take your advice and make sure there is plenty of weight on the back end
Cheers
   / MK5000 #6
if it is the same as the MX series, i once owned a MX5000 for a while. although bare bones (clutch operated shuttle shift, syncro in 3rd/4th gears only) i found it a rock solid machine somewhere between CUTS and the M series ag tractors. i agree on rear ballast best regards
   / MK5000 #7
The MK is the Euroean version of th MX. It has the EU smog stuff and they state it only puts out 48.8HP as opposed to 50HP for the MX. Not sure you would notice the difference. Why not check out the MX prices and compare?
Tractors Kubota MK5 - Kubota
   / MK5000 #8
How are EU emission and standards different from USA? Suppose the tractor is different in other ways?
   / MK5000 #9
Different enough to knock 1.2HP off essentially the same turbocharged engine.
New/Unused AGT Industrial LRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
43030 (A51691)
43030 (A51691)
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
