Buying Advice MK5000
/ MK5000 #1
Mikeydpl
Cornwall. England
Mitsubishi MT 180D
Hi
Anyone on here have or had one of the above Tractor, about to get one and would appreciate any comments
Thanks
Mike
/ MK5000 #2
It looks like our MX5000, MX5100, etc. If it is, it's one of the best tractors Kubota every made and is wildly popular around here. I don't know of any problems and sure don't have any with mine.
/ MK5000
Hi
Thanks for the reply,not sure what the difference is between the MX and MK but as you said they look the same, thanks again sounds like I have made a good decision
/ MK5000
Great tractors. Load tires, AND add wheel weights if you get an fel... they are way light in the butt...
Yes getting a FEL with it, will take your advice and make sure there is plenty of weight on the back end
Cheers
/ MK5000 #6
if it is the same as the MX series, i once owned a MX5000 for a while. although bare bones (clutch operated shuttle shift, syncro in 3rd/4th gears only) i found it a rock solid machine somewhere between CUTS and the M series ag tractors. i agree on rear ballast best regards
/ MK5000 #7
The MK is the Euroean version of th MX. It has the EU smog stuff and they state it only puts out 48.8HP as opposed to 50HP for the MX. Not sure you would notice the difference. Why not check out the MX prices and compare?
Tractors Kubota MK5 - Kubota
/ MK5000 #8
How are EU emission and standards different from USA? Suppose the tractor is different in other ways?
/ MK5000 #9
Different enough to knock 1.2HP off essentially the same turbocharged engine.
/ MK5000
Thanks, I don’t think the loss of 1.2 hp will be anything to worry about
Thanks again to all who have replied, haven’t used the forum much but intend to a bit more now, will post a few pictures when it arrives
Cheers
/ MK5000
/ MK5000 #13
Congrats .... Looks like you got a great tractor.
/ MK5000 #14
Nice looking tractor. With the color similarity with that "other" orange brand, I'm surprised the Name isn't more predominant. Not even on the Loader. How will the neighbors know you bought a genuine KUBOTA?
/ MK5000
The Loader is made by MX (chilton) and sprayed Kubota Orange, couldn't get a Kubota loader as apparently none available for this Tactor, it does have a big Kubota badge on side of bonnet so neighbours should see it when they peep over the hedge .
/ MK5000 #17
I was wondering if that might be the case. That explains That!
So, Leave the Loader up when you park it! lol
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
6 Band Wooden Barrel (A61569)
6 Band Wooden...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
