Ballast mixing windshield washer fluid with water 4 ballast
   / mixing windshield washer fluid with water 4 ballast #11
I would think a 50/50 mix would be good to almost zero degrees. That should be plenty in South Carolina.
I think no more than it will cost, I will go full strength and a pint of lubricant. thanks to all for your answers. zman:thumbsup:
   / mixing windshield washer fluid with water 4 ballast #14
How much will it weaken WWF with water if I use it to fill rear tires? Planning on half and half. It says on the label, -20 degrees. I know this is when used full strength. It very seldom gets below 20 degrees here where I live. Thanks for any response. zman ;)
That 20 is probably at nite. Does it then go to 44 in the day? If so you could use plain water. I use it well into December here in north central VA-then drain.
larry
My stepson just got back with 21 gallons of it, and the water pump lubricant. I am about to do it. I will let yall know if it makes a difference pulling. I am pulling a 5' box blade with this little tractor, which is big for this tractor, I know. Hey but more power. LOL test her out. zman :D
   / mixing windshield washer fluid with water 4 ballast #16
Well it wouldn"t surprise me if these ain"t the original tires on this tractor. they are ag tires. So kind of old, but they hold air well. Only added air once in a year. So how about full strength wwf and one pint of water pump lubricant in each tire?:thumbsup:
I myself wouyld stay away from water. I have seen tractors with major rust on the rims. Makes me wonder what the tires are filled with.
Have you considered a Ballast Box.?? That's the way to go, IMO.:thumbsup:
Wellllllllllll, after about 30 minutes of trying to gravity feed it, with the 15 gallon tank I had, I tried to use the little 12 volt pump on it, only to find out it doesn"t work. I"ve had it quite awhile and never used it. So, I will try again tomm. I know I filled one set before and they were a lot more smaller tires and it seemed like it took forever, gravity filling. zman
   / mixing windshield washer fluid with water 4 ballast #18
Take the tire off, partially break down one side..........just a small opening.............pour the fluid in, air up, put wheel back on and go.
can you just break one part of the tire loose with it on the tractor?
JDGREENGRASS, I dont need a ballast box, I"m pulling a box blade.
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
4 SEMI MOTOR SHIPPING BLOCKS (A58216)
4 SEMI MOTOR...
2016 John Deere 35G (A55272)
2016 John Deere...
2015 Caterpillar 305.5E2 CR (A57148)
2015 Caterpillar...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
2007 Jeep Liberty 4x4 SUV (A56859)
2007 Jeep Liberty...
