Oil & Fuel Mixing udt and gear lube
   / Mixing udt and gear lube #1
Derf
BX25
I am low on fluid in the front axle (BX25). Will it hurt to add gear oil as I can't get any sudt for a few days.
   / Mixing udt and gear lube #2
I don't believe a few days will matter much.
I actually remove the SUDT/UDT front fluid from my tractors' front axles and replace it with 85-140 Shell Spirax because they receive high shock loads in the farm work I do but I've always did that, even with my previous, smaller Kubota's.
Never a failure, leak or concern in the last 15 years.
   / Mixing udt and gear lube #3
I changed mine out to 75w/90 synthetic. I think the thicker oil is a lot better for the gears and less of a chance for leaks.
   / Mixing udt and gear lube #4
All late model Kubota front drives are hermetically sealed against leakage. I do it solely for shock load.
The U/SUDT will flow better in the winter allowing more power transfer (until the drive is warmed up) but once it's warm, the hypoid provides much better lubrication.
   / Mixing udt and gear lube #5
I have been topping mine off with 75w140 since it started leaking a year ago. The oil is mainly used as a lubrication bath so in theory you could drain it all and replace it with just about any oil because the axle is not spinning at a high rate of speed so heat is not much of an issue but due to the loads placed on it I would stick to a gear oil.:)
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
UNUSED FUTURE SKID STEER MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
RIGID TOOLBOX (A52472)
