Mixing tires
   / Mixing tires #1
Turbo5upra
Bronze Member
Central NY
Case 300
I recently bought L4350 with a backhoe... it痴 been a really wet spring. With the hoe on the tractor is afraid of its own shadow- with it removed I get around pretty good but wish it had r1痴 on it. I知 wondering if it痴 a bad idea to mix types of tires front to rear since the fronts are easy and pretty cheap to swap if bought a pair of r1痴 to replace the r4痴. The current tires are in great shape and I think I could get a fair amount for them.
Do you think this would help much and would it be ok for the tractor?
Thanks guys!
   / Mixing tires #2
Bad idea without changing both fronts and rears. Then you would also need new rims. R1s require a different size than R4s.
I think your best bet would to purchase a good set of tire chains. I find mud is the hardest and messiest thing to deal with.
   / Mixing tires #3
If I understand things correctly its the diameter of the tires that causes problems. The correct ratio of diameter of the tires front to back affects the drive components. So be sure the front tires are the correct diameter.
   / Mixing tires #4
This applies if the tractor is 4WD. 2WD, not so important
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2000 Ford Ranger Pickup Truck, VIN # 1FTYR10V0YTA06580 (A51572)
2000 Ford Ranger...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
