Mixing hydro/trans oil
   / Mixing hydro/trans oil #1
Slab
Ny
Yanmar sc2400
Is it ok to mix different brands of hydraulic -transmission oils ? Or are they all the same to meet the demands of such a system.
   / Mixing hydro/trans oil #2
It's best to use fluids that carry the manufgs specifications. Don't mix unless absolutely necessary. JD Fluids are especially critical.
   / Mixing hydro/trans oil #3
What is it ? A JD model D or a JD 7320 ?
Something with wet clutches, wet brakes? Hypoid final drive gears?
It's a Yanmar SC2400. All the manual says is to use a hydraulic - transmission fluid (TF 500)
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
Sterling AT (A55301)
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Woven Landscape Fabric (A53117)
Woven Landscape...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
