Mixing hydraulic fluids
   / Mixing hydraulic fluids #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
After adding front snowplow angle cylinders from the rear remotes to my kioti ck35, I'll be needing to add hydraulic fluid. Can I mix about a gallon (maybe less) of Traveller Universal Tractor Trans/Hydraulic Fluid to the Mobilfluid 424 that's already in the system.
   / Mixing hydraulic fluids #2
Sure can.
   / Mixing hydraulic fluids #3
These oils have little to no additives. Think it would be safe to mix them.
Ralph
   / Mixing hydraulic fluids #4
I think you'll be ok
   / Mixing hydraulic fluids #6
Ralph
??? These oils have special additives for friction of the PTO clutch, and wet brake squeal and chatter, rust protection, foam suppression, ect ect. CJ
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
