Mixing fluids
/ Mixing fluids #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
My L5030 developed a hydraulic leak and lost a couple gallons of fluid. The unit has 250 hours on it. Previous owner had fluids changed by dealer at 100 hours but didn't know what fluid was put in it.
I seem to recall that it is really, really bad to mix UDT and SuperUDT (assuming the dealer put a Kubota-branded oil in there at all!). So...am I stuck replacing all of the fluid and both hydraulic filters at this point or would I be safe topping it off with UDT or SUDT and waiting to change it all at the recommended 500 hours?
/ Mixing fluids #2
5030T I don't think that it would really hurt it either way, but when I buy some used, I always change everything right off of the bat. That way, I know what has been done, when and what with.
/ Mixing fluids #3
I wouldn't worry about it. They are compatable just the Super for the most part is a little thinner.
/ Mixing fluids #4
I don't know the answer to your question, BUT I do remember a point that had to be emphasized to young Armour soilders. The old M47 tank had a wide assortment of fluids for various reasons. We had to make sure everyone :confused: knew that you cannot mix 20 W oil with 30 W oil
and get 50 W oil.
HAPPY NEW YEAR! to everyone reading this post.
/ Mixing fluids #5
You recall wrong. UDT and SUDT are completely compatable. Non-Kubota UDT equivalent fluid is also compatable with either. Put whatever you have in there - it won't make a difference. If you don't have anything already, buy a 5 gallon bucket of $25-30 generic UDT and toss the couple of gallons in.
JayC
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61573)
2016 Peterbilt 579...
2018 John Deere 8370R (A64119)
2018 John Deere...
43018CFL (A59228)
43018CFL (A59228)
2017 Ford F-250 Ext. Cab Pickup Truck (A61573)
2017 Ford F-250...
