Mixing different weights of oil
   / Mixing different weights of oil #1
sleeper
I did a search and couldn't find anything conclusive. I know its not good to mix different makes. But is it ok to mix different weights, i.e. 5w-30 and 30wt. Thanks.
   / Mixing different weights of oil #2
From what I've read it is generally not advised to mix different weights. The mix is not 5W -30 and it is not 30w either. It would be better than running out of oil in a pinch, but I wouldn't mix it otherwise.
   / Mixing different weights of oil #3
It does not hurt to mix different weights or different makes.
   / Mixing different weights of oil #4
Not so sure it hurts but there are some oil manufacturers that advise against it even within their own oils:eek:
I asked Mobil about mixing their Delvac 1300, a mineral 15w-40, with their "synthetic" 5w-40 and they said it wasn't advised. :confused:
I had already done it in my motorcycle and the bike never shifted smoother...don't know what their exact concern was.
   / Mixing different weights of oil #5
At Exxon, our lube planner would mix base stocks, 5 grade into 10 grade, 30 grade into 10 grade, etc. This is to make viscosity, flash point, boiling point, etc. on a particular base stock. It wasn't done a lot, but there certainly weren't any rules against it. We didn't go mixing huge amounts of 30 and 10 grade to made a 20 grade, for instance. Standard dino oil is a whole spread of molecules but with the average generally giving it the desired vis grade and boiling point. I've put together lube oil blending programs that mix all the properties. We had NO REASON from a research or engineering standpoint to prohibit what went into the blends, as long as the product was on spec. We generally fractionated the oils from the stills to make specifications as carefully as we could, to eliminate blending, because running more narrow cuts franctions through our dewaxing plants made them run better, and we generally didn't want to do blending in the end. However, we had no problem with doing a little end blending to make specifications.
Do not mix dino with synthetic. Otherwise, you've wasted your money that you paid extra to get the very pure synthetic. However, if it's a choice of an engine or gear box running out of oil vs. mixing, then mixing is fine.
A couple of times, I've mixed 15w50 with 5w30 to get 10w40 grade for my old Benz. Lately, I've been able to get 5w40 or 0w40; so this is what I use in it.
Ralph
   / Mixing different weights of oil #6
Doesn't someone already carry a blended synthetic product.. thouhgt I had read about it somewhere.
soundguy
   / Mixing different weights of oil #7
Several companies make synthetic blends. I have two cases of Valvoline Durablend sitting at home for my next two oil changes on the Suburban.
   / Mixing different weights of oil #8
2 cases for 2 oil changes, wow, even with cases now meaning only 12 quarts thats a lot of oil for 2 changes.
   / Mixing different weights of oil #9
My truck is 10 qts per change.... having 2 cases isn't that much. I do 2 changes a year. Spring goes to 15w40 and fall goes to 5w40. Lucky is doesn't burn any.
jb
   / Mixing different weights of oil #10
LOL - Durablend and many synthetic oils come in cases of 6. My truck uses only 6 quarts.
Now, my other truck with a Cummins diesel does use 12 quarts or 3 gallons per oil change. But if you buy oil in gallon jugs at Wallyworld it's not too bad (still not cheap!).
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
BELSHE DT-235 (A53843)
