mixing concrete - or not?
   / mixing concrete - or not? #1
bdog
Elite Member
Texas
John Deere 6130M
I just got through setting 46 posts and builing a fence around my place. We used 2 sacks of quickcrete per hole and mixed it up first and poured it in the holes. I had a buddy stop by and tell me that I was doing a lot of uneccessary work. He said to put the posts in the holes, pour in dry concrete mix, then add water and it will be fine, no mixing required.
I am going to be setting 25 more posts this weekend and am contemplating doing this as it will save a lot of work, but I am not sure if it is a good idea or not?
   / mixing concrete - or not? #2
Your friend is right.
The real question is wether you need to add water or just put it in dry and leave it. Lots of folks do it either way with good results.
I like to add a bucket of water myself, but the most important thing is to build up the mix along the post and angle it down and away. You want to create a path for the water to drain away.
Eddie
   / mixing concrete - or not? #3
Most put it in dry. I'd guess wet dries to a little better compressive strength if you ran the test. I have done it before in a different application and it wasn't as hard as full wet might have been, but it was way beyond what a fence post needs. Still took a sledge to break it up.
   / mixing concrete - or not? #4
IMO,mix it. You've already gone through all the trouble of digging holes. Why risk not getting the posts set firmly if the concrete isn't right? With that many posts, I'd rent a gas powered mixer that you can tow behind your truck/tractor.
My neighbor installs fences for a living. When he replaces peoples fences, he can tell which ones did the dry hole method.
   / mixing concrete - or not? #5
The Civil Engineer in me just can't deal w/not fully mixing concrete before putting it around the post so that's what I do. I also put several shovels of gravel under the post so it won't sit directly on wet ground & soak up moisture & rot fast.
Others dump quickcrete in dry & pour water on top. 2 different schools of thought, as long as the posts don't move I guess it does not matter.
   / mixing concrete - or not? #6
My neighbors and I did it the other way around. We dumped a bucket of water in the hole, then dumped in the sackrete after the water instead of before, then "mixed" it with just an up and down motion with a steel rod, usually a piece of half inch rebar.
   / mixing concrete - or not? #7
I've set a lot of poles dry if the ground was moist. when the ground was really dry & i had a water source nearby, i poured in a little water on top. can't tell any difference. they all seem tight.
   / mixing concrete - or not? #8
what you didn't say is what type of post?
PT, std lumber, wood species (aka cedar ect.) or steel.
some absolutly no concrete others work OK with concrete in hole. most times as a decrotive fence crete is not neded if compacting the posts base some with some gravel under em.
anyhow storming here & have to shut down.
markM
   / mixing concrete - or not? #9
I mix it in a concrete mixer for a couple of reasons.
1. It's cheaper. Of course I do hundreds of cubic yards a year. But when you figure my holes are one foot by three and a half to four foot deep minimum and an eighty pound sack of sacrete provides six tenths of a cubic foot, well, six to seven bags per hole. /forums/images/graemlins/blush.gif
2. I've pulled a lot of posts in my time. If they're sacreted the first thing I do is hit the post with the sledge. Nine times out of ten if they were dry set a couple of hits with the hammer and I can lift the post while leaving the concrete.
3. Dry setting is like painting a car with today's paint and then not applying a clear coat. It's hard to tell the difference......for awhile. /forums/images/graemlins/grin.gif
   / mixing concrete - or not? #10
Nice analogy there Harv,
I agree with mixing. Although Im definately guilty of doing it the cheap way, I guess you know theres the right way to do it, and theres that way that gets you by. Its like saying, hey can I change my brakes and not change my fluid? Well yes you can but youd really miss a good oppurutuntiy to do it right
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
EZ-GO Textron Electric Cart (A51694)
EZ-GO Textron...
1999 Ford F-550 12FT. Flatbed Truck (A51691)
1999 Ford F-550...
