mixing 90 wt. and multi viscosity 85-140
   / mixing 90 wt. and multi viscosity 85-140 #1
tglass
Platinum Member
3320 w/cab
Have been told the two cannot be mixed together. If they are, curdilling, or a non mix will happen, with bearing failure soon to happen. Anyone have any thoughts or better yet facts or publications on the subject?
   / mixing 90 wt. and multi viscosity 85-140 #2
I would expect that they would mix. Try mixing some yourself and see. Mix them in a clear container and see if you detect anything wrong. see if theyfeel different. I don't think I've ever heard of two oils not mixing.
   / mixing 90 wt. and multi viscosity 85-140 #3
</font><font color="blue" class="small">( Have been told the two cannot be mixed together. If they are, curdilling, or a non mix will happen, with bearing failure soon to happen. Anyone have any thoughts or better yet facts or publications on the subject?
)</font>
Personally..I wouldnt INTENTIONALLY mix them. What do you wind up with?? For a gear oil change Id just drain the "old" 90...and install the new stuff....I wouldnt worry about FLUSHING the old 90 out...but I sure wouldnt "pre-mix" the 2 into some sort of combo to install fresh.
   / mixing 90 wt. and multi viscosity 85-140 #4
I did it today in my post hole digger gear box. One quart of 90wt and two quarts of 85-140wt. Not something I'd worry about in this application.
Eddie
   / mixing 90 wt. and multi viscosity 85-140 #5
I've done the same thing before on implement gear boxes. I would assume it would mix as long as they were both petroleum based products. I don't see how they could get into that "curdling" situation. That sounds more like the oil & water scenario.
John
   / mixing 90 wt. and multi viscosity 85-140 #6
I don't know what part of the country you are in but I don't suspect mixing would do any harm. Its like mixing straight 20 weight oil with 10w-40. The multi viscosity oil flows better in cold temps. Same would be true for gear lube.
   / mixing 90 wt. and multi viscosity 85-140 #7
The 90 wt is likely from a more naphthenic crude; whereas, the multi-wt is likely from a more paraffinic crude. They mix fine.
Ralph
Lost me from the start. What is the difference? Thought all oils mixed unless a water base. As I get older I learn alot more, so be patient. It just takes a little more time.
   / mixing 90 wt. and multi viscosity 85-140 #9
I also think they would mix fine. I've got a gearbox that actually reccomends using a flowable 0# grease, or if you can't find any, then to shoot a tube of grease in then add a few ounces of gear oil 'such as 90wt or 85/140' to partially liquify the grease. neat huh...
Soundguy
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
