mitsubishi
/ mitsubishi #1
snoopy
mitsubishi 1800 4wd
have a mitsu 1800 ll rd 4 wheel drive having hard time with parts air filter, hyidrolic filter etc also a driveshaft help!!
/ mitsubishi #2
I think if you scroll around this site there is a Mitsubishi section and then there are a few dealers on here that can get you parts or numbers
/ mitsubishi #3
There is a Mitsubishi forum here: Mitsubishi/Satoh - TractorByNet.com
On my girlfriend's D1800 (2wd) the air filter is a normal tractor filter. Take the old one off and go to Napa or your local tractor dealership and have them match it. It shouldn't matter which color/brand. It's the same filter as is on my Yanmar and International Harvester, and I've seen one like it on Deeres and an Allis-Chalmers. I've bought them at the local Kubota dealer.
Hers doesn't have an external hydraulic filter. It's probably just a screen inside the transmission case.
Post in the Mitsubishi forum, and be patient; it's not very active compared to the others, as a rule. Be as specific as you can, too. What's wrong with the driveshaft? Is it missing? Broken? A driveline shop can build you one. I'm assuming it's the front. Good luck!
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2004 Talbert Lowboy Detach Trailer (A64047)
2004 Talbert...
2007 FREIGHTLINER COLUMBIA 120 DAYCAB (A63569)
2007 FREIGHTLINER...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
PAIR OF TRACTOR TIRES AND RIMS (A63569)
PAIR OF TRACTOR...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
