Mitsubishi Transmission
   / Mitsubishi Transmission #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I have a Long Landtrac 470 with a Mitsubishi engine and transmission. Trans is 4 speed synchromesh, with high and low range and a creeper with high and low, so 16 speed with a synchromesh shuttle. The transmission will not shift into 1st or 2nd, 3rd and 4th work fine. It does not grind, just will not go into gear. Could it be adjustment? I have looked at the linkage and it appears to be in fine shape, not bent or jammed up. Anything simple I might try? An overhaul means taking all the tin and loader frame off. $2000+ labor, before parts, not sure it is worth it. Sure wish I had high range 1st!
   / Mitsubishi Transmission #2
It would be a great help knowing what Mitsubishi engine is in your machine. Otherwise, I can't even make a comment here.
It is a 4 cyl 47hp. Non turbo diesel.
   / Mitsubishi Transmission #4
Still doesn't say much of anything. What is the engine ID plate state? Is it a K3x or K4x or SLx or Lxxxx series engine???
   / Mitsubishi Transmission #5
TD shows this, not much info there either.
TractorData.com Long 470 tractor engine information
Download this PDF and compare,
   / Mitsubishi Transmission #6
Probably a stupid question but did you check the oil level in the transmission ?
About 10 years ago the transmission in my 8N Ford wasn’t shifting properly and when I checked the oil it was about 2 quarts low so I added oil and it’s back to shifting great
Transmission and hyd system all one and I'll check it.
2013 KENWORTH T800(INOPERABLE) (A48992)
2013 KENWORTH...
2010 FORD EXPEDITION (A48992)
2010 FORD...
18FT MIDLAND CARRIER SPOOL TRAILER (A48992)
18FT MIDLAND...
2007 Ford E-350 Cargo Van (A48081)
2007 Ford E-350...
2012 Challenger MT465B 105 HP Agricultural Tractor (A49346)
2012 Challenger...
377893 (A48837)
377893 (A48837)
