Mitsubishi S750D PTO engagement question
   / Mitsubishi S750D PTO engagement question #1
bigbach007
Mitsubishi/Satoh Stallion S750D ; International 464 ; Allis Chalmers CA
Hello everyone. Happy new year! I have a S750D with a loader on it that we bought at a farm auction a few years ago. I've never used the PTO on it but recently the tractor I usually use for running PTO implements broke and I want to do some brush-hogging with this one. Its stickered on the side of the hood "Live PTO" and the PTO selection lever has 3 positions, OFF (centered), 540rpm (front), and 1100?(back). My issue is, the PTO will not engage without really grinding the gears when there is a load attached to the PTO shaft. It seems like maybe the clutches for the PTO are stuck in the "engaged" position? Pressing the clutch for the drivetrain doesn't affect the PTO. Does anyone on here have experience with the PTO on these tractors and how to operate them? I'm not sure if I'm missing something or if the clutch pack is just stuck and preventing the PTO from engaging smoothly. Someone suggested the tractor has a 2-stage clutch for drivetrain and PTO but that doesn't seem to be the case to me. For now, I'm engaging the PTO with the tractor off and then just starting the tractor (not a great setup but it works).
   / Mitsubishi S750D PTO engagement question #2
I'm not familiar with that model but when engaging the PTO the engine should be at idle. If your gears still clash your clutch may need adjusted. After the PTO is engaged you may bring it up to speed.
Hey @Roadworthy Thanks for the reply. So i was looking again last night and it is indeed a 2 stage clutch like that other guy mentioned to me. I think it is just out of adjustment.
Heavy Duty Plate Compactor (A47371)
Heavy Duty Plate...
INOP/NON-RUNNING 2012 Ford F-450 Pickup Truck, VIN # 1FD0W4HT2CEC31215 (A48836)
INOP/NON-RUNNING...
Stainless Steel Hog Feeder (A49251)
Stainless Steel...
Brush Hog (A49251)
Brush Hog (A49251)
Towable Orchard Sprayer (A49346)
Towable Orchard...
2011 PETERBILT 365(INOPERABLE) (A48992)
2011 PETERBILT...
