Mitsubishi S4L2 info?
   / Mitsubishi S4L2 info? #1
887
canada
montana r3644
So I'm doing some general service work on a relatives montana R3644, which I think is the same or close to the R3039 LS with the S4L2 Mitsubishi engine
Oil has been changed every 125 hrs, I was cleaning the engine off and noticed a oil filler cap on the injector pump. Cant seem to locate the manual at this time, don't remember seeing anything about changing injector pump oil.. Does anyone know if it has separate oil that needs changing or is this just simply another oil fill point?
Thanks
   / Mitsubishi S4L2 info? #2
Most likely just another fill point.
These engines are used in lots of applications. Some times filling from the top, works better than from the side, and vice versa. It also applies for other engines manufacturers.
On these more recent tractors, only a few the Chinese brands are the only ones that require oil changes on the injection pump that I'm aware of.
   / Mitsubishi S4L2 info? #3
It is an oil fill point. The fuel injection pump sits in the crankcase.
BTW, you can download an operators manual at RCO Tractor website.
Thanks guys! We found the book today too! Some older ford tractors had injector pump oil you had to change, so was worried it might be the case with the Mitsubishi.
Been a great engine so far
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2016 Kubota RTV-X1100CR-A (A55272)
2016 Kubota...
Informational Lot - Shipping (A56438)
Informational Lot...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Toro z turn (A56859)
