Mitsubishi mte200d lift arm help
   / Mitsubishi mte200d lift arm help #1
Mitsutractor
Greensboro, nc
Mitsubishi mte2000d
Hello, I am new to the Forum and need some help. I recently purchased this tractor and everything works well. It has an accutech 300 loader which works perfectly but the lift arms won't raise up. I have removed the loader from the hydraulic system and hooked the pressure line directly to the 3 pt valve assembly with no change. Any ideas?
   / Mitsubishi mte200d lift arm help #2
If the loader works perfectly, then wouldn't it stand to reason that the lift arms are part of that operation. There are potentially quite a few individuals on this forum that have many answers, but I believe some additional information would be helpful in troubleshooting this problem.
   / Mitsubishi mte200d lift arm help #4
Under the seat is a valve that controls the hydraulics to the lift arms. Have you tried changing positions of the valve? might be that simple.
One setting is off, and the others control depth.
   / Mitsubishi mte200d lift arm help #5
You say the loader works perfectly, but the lift arms will not raise.
Does the bucket tilt work?
Does the 3pt work?
If the other hyd components work, what happens when you try and raise the lift arms.
Do you hear any noise, a relief valve, anything.
I would install a hyd gage in a tee in the IN port of the loader valve, and observe the readings for pressure or no pressure.
You might remove the caps on the bottom of the loader valve and check the centering spring. Tighten if necessary.
Your float apparatus will also be under the cap.
   / Mitsubishi mte200d lift arm help #6
I have a MT 16D the hydraulics for the lift arms on it are controlled by electric solenoids not sure if yours is the same but it could be an electrical problem if it is.
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
kids dirt bike (A53424)
kids dirt bike...
66'' root grapple (A53421)
66'' root grapple...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
