mitsubishi mt372d
   / mitsubishi mt372d #1
eut
I have problem with the starter.It spins but does not engage.
When it does engage it turns the motor one explision and it
immediately disengage.Do I need a new starter...Pse help
   / mitsubishi mt372d #2
Regrettably this sounds like some of the teeth on the flywheel are wiped or close to it. This can happen when the starter engages at the same spot for many years. It happened to me. Check the teeth first before you waste money on starters like I did. Hope I'm wrong!
   / mitsubishi mt372d #3
I can furnish a replacement flywheel (used) and a rebuilt starter should you need one. Call toll free 1-800-609-5110. Bill - satohparts.com
   / mitsubishi mt372d #4
Sounds like a bad starter drive. I can supply new , used , or rebuilt or the parts to rebuild it.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
7ft Double Legs Lifting 5/16 G80 Chain Sling (A49462)
7ft Double Legs...
Universal Adapter Plate Skid Steer Attachment (A49462)
Universal Adapter...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
