Mitsubishi MT372D overheat
   / Mitsubishi MT372D overheat #1
bestormy
Wisconsin
Mitsubishi MT372D
My MT372D overheats when cutting grass for more than 30 minutes. Radiator exterior is clean. Water pump? Thermostat? Radiator plugged? What should I check first?
Also, oil overflows from the top of the gear box through shifter hole when the engine is hot. Is this just an overfill problem?
   / Mitsubishi MT372D overheat #2
I know you said radiator exterior is clear, but did you pull the front grill and hose it out good from both sides? I had the same problem at one time and the grass seeds were down in between the fins and couldn't be seen. Hosed it out and has been good ever since. I try to do this at least twice a summer unless I let the field get away from me then it is more often.
I removed the grill and inspected - the radiator exterior is very clean.
   / Mitsubishi MT372D overheat #4
Mine overheated also a few years ago . I got a "trouble light" and held it behind the radiator and it was actually quite plugged. I took a tooth pick and an air "blow gun" to it and it has been good ever since ! Try the light first and take a look . If this doesn't fix it , let us know . It's not rocket science. Just like a car with a thermostat.(Some of the older Satoh/Mitsubishi's don't have thermostats). Can you see the water circulate in the top of the radiator when it gets hot? It is possible the pump is bad or the thermostat is bad , but not likely.
Alvanko and Dadzilla - Thanks for the good advice. After further review, I found the radiator fins were plugged with seeds and other fuzzy stuff that inhibits cooling. I didn't realize how far they get packed in. I used my power washer on low velocity to flush out the holes without bending any fins. Now I can see light through the radiator. I only wish I had a warm day to test it out. Thanks again - I owe you two a beer. /forums/images/graemlins/grin.gif
   / Mitsubishi MT372D overheat #6
Your welcome. Thats why we're here.
   / Mitsubishi MT372D overheat #7
/forums/images/graemlins/tongue.gif Keystone Light for me please. Glad we could help you out!
   / Mitsubishi MT372D overheat #8
KEYSTONE! Man it's free you can have a Yuenglings. /forums/images/graemlins/shocked.gif
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2442 (A60432)
2442 (A60432)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
