Mitsubishi MT372D Hydraulics
   / Mitsubishi MT372D Hydraulics #1
Paul Casey
I have a Mitsuibishi MT372d tractor all the hydrualics worked correctly prior to changing the hydraulic oil filter and replacing the oil, I used Mystic ISO 46Hydraulic Oil. Now every thing workd including the bucket tilt the only thing that does not work is the lift' it went up about a half inch and that was it any ideas would be great .
How full should the reservor be manual calls ot 3.6 gal but the reservoris still low should it be filleD?
Paul
   / Mitsubishi MT372D Hydraulics #2
Just had a similar incident and same scenario years ago on another Mitsubishi I owned. If fluid is full, filter clean and other hydraulics are working fine, it is most likely a small piece of crud holding the relief valve partially open or said crud in the 3point control valve. A very small piece of debris can render either of these two parts nonfunctional. Neither is an overwhelming task (I know, it sure isn't a fun thought!) but a manual, an afternoon of your time and a very basic collection of tools will solve your problem.
My experience with these tractors is that even the "more" involved mechanical work like splitting them for a new clutch or cracking open the transmission or differential case sounds much more daunting than it really is.
Darryl,
Thanks you for the reply I will give that a try.
Paul
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
2020 JOHN DEERE 333G SKID STEER (A51242)
2020 JOHN DEERE...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
