Mitsubishi MT372D Hydraulics
   / Mitsubishi MT372D Hydraulics #1
Paul Casey
I have a Mitsuibishi MT372d tractor all the hydrualics worked correctly prior to changing the hydraulic oil filter and replacing the oil, I used Mystic ISO 46Hydraulic Oil. Now every thing workd including the bucket tilt the only thing that does not work is the lift' it went up about a half inch and that was it any ideas would be great .
How full should the reservor be manual calls ot 3.6 gal but the reservoris still low should it be filleD?
Paul
   / Mitsubishi MT372D Hydraulics #2
Just had a similar incident and same scenario years ago on another Mitsubishi I owned. If fluid is full, filter clean and other hydraulics are working fine, it is most likely a small piece of crud holding the relief valve partially open or said crud in the 3point control valve. A very small piece of debris can render either of these two parts nonfunctional. Neither is an overwhelming task (I know, it sure isn't a fun thought!) but a manual, an afternoon of your time and a very basic collection of tools will solve your problem.
My experience with these tractors is that even the "more" involved mechanical work like splitting them for a new clutch or cracking open the transmission or differential case sounds much more daunting than it really is.
Darryl,
Thanks you for the reply I will give that a try.
Paul
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
