Mitsubishi mt372
/ Mitsubishi mt372 #1
Soots
Inverness, Florida
mt372
Hello I'm new here, hope I can find help. I found Diesel in crank case. both cylinders were trying to fire, so I think I can rule out a a busted cylinder. will fuel pump let fuel pass into block?
/ Mitsubishi mt372 #2
You might get a quicker answer in the Mitsubishi/Satoh forum. Generally though I think a lot of diesels have an oil seal in the injection pump. If it goes bad, diesel can get into the crankcase.
/ Mitsubishi mt372
thanks oliver,
There is a line coming from the fuel tank to a squarish gizmo, with two lines coming out, one to each cylinder. Would that squarish gizmo, (I think that is the real technical name) would that be the injector pump? As you might guess my profession is not mechanic. Soots. (Rick.)
/ Mitsubishi mt372
well, it sounds like I need a new injector pump. any help out there?
/ Mitsubishi mt372 #5
Your hypothesis seems like a good one. If you don't have a manual here are a few pertinent pages about the injector pump. They are photos of my manual, the best I can do. IMG_2035.jpgIMG_2032.jpgIMG_2033.jpgIMG_2034.jpg
/ Mitsubishi mt372
Thank you Skylarkguy, I'm on my iPhone now and can't read pages, later I'll check it out on my laptop. Is there another way for fuel to get into crank case?
/ Mitsubishi mt372
Can I remove injector pump, send it to a shop for rebuild, then reinstall it? What problems should I be looking for. I replaced many fuel pumps, water pumps, etc, years ago on 283's, 305's and such. Those were not problems. One mechanic warned me of "shims, it might not line up right". Was he trying scare me so I would hire him to do the work?
/ Mitsubishi mt372 #8
I don't know a thing about your tractor, but just some general diesel knowledge.
The repair shop will set the pump at Top Dead Center. You must set the motor to TDC before reinstalling the pump. Then of course you'll have to deal with bleeding air from the fuel lines. Other than that it should be easy.
/ Mitsubishi mt372
Thanks DT86;
I pulled pump and have it in a bucket. I'll find someone in Orlando tomorrow. I'll gladly take anymore advise and ideas. Thanks Rick.
/ Mitsubishi mt372
Does anyone have a recommendation for an injector pump rebuilder in Orlando, Ocala, or Central Florida?
/ Mitsubishi mt372
I dropped off my pump at Southeast Power on Orange Blossom Trail in Orlando, 800-733-6101. I spoke with Kevin, I told him I blew into the pump while blocking the out put lines, and air freely blew through. He told me My crank case would fill with fuel. which it did. So, I felt confident in his company. to rebuild the pump. He's gonna call me with a price later, that scares me a little. I'll keep you posted.
/ Mitsubishi mt372 #12
Good luck! Hopefully it won't break the bank.
/ Mitsubishi mt372
I got the call today. the cost to rebuild my injector pump is, $260.00. It sounds like a lot for a 3" x 3" piece of metal.with a few springs and levers. But the tractor wont run without it.
/ Mitsubishi mt372 #14
That's not bad as far as rebuilding a pump.
/ Mitsubishi mt372
I have to go back to work on tues. and the pump won't be ready. I work on a supply boat in the Gulf of Mexico, so the tractor will set for a month or two till I come back home, (sucks, am trying to retire). I put all my tools away, and bolted everything back in place, stuffed a rag where the pump goes. I've really enjoyed this forum. It has really taught me quite a bit. Your replies gave me the courage to do this repair, and I'm finding it a lot of fun. I would probably enjoy all of your company in a coffee shop. you have really made me feel welcome. Thanks to all.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
INSPECTION (A65563)
INSPECTION (A65563)
3268 (A63117)
3268 (A63117)
Butler MFG Water Tanker (A63689)
Butler MFG Water...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
2022 EZ-GO ELITE...
