Mitsubishi MT250D Hydraulic question
   / Mitsubishi MT250D Hydraulic question #1
Brian KM
Blairsden, Ca
Mitsubishi MT250D
Does anyone know what the GPM and the PSI is for the hydraulic pump on this tractor? It is a 3 cylinder, 25 horse power Ford with a 25 hp PTO as well. The manual says the hydraulic relief valve is set at 2300 PSI which makes me assume it is probably a 2000 PSI pump but I can't find anything on GPM. I am trying to figure out if it has the power & speed to run a 3 point hitch log splitter that I am eyeing.
Thanks!
   / Mitsubishi MT250D Hydraulic question #2
You tractor can support 16 GPM at 2300 psi, but the attachment flow is probably about 8 GPM.
An equivalent Kubota would have about 6 to 8 GPM.
As far a funning a log splitter, answer is yes.
GPM determine the speed and pressure determine the force.
So if using a 4 in cyl with a pressure of 2300, the force would be about 14T.
If you wanted more speed, Prince makes an LSR log splitter valve that will use 4 GPM and make that into a 25 GPM log splitter.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55301)
JOHN DEERE ROW...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
