Mitsubishi MT250D Hydraulic question
   / Mitsubishi MT250D Hydraulic question #1
Brian KM
Blairsden, Ca
Mitsubishi MT250D
Does anyone know what the GPM and the PSI is for the hydraulic pump on this tractor? It is a 3 cylinder, 25 horse power Ford with a 25 hp PTO as well. The manual says the hydraulic relief valve is set at 2300 PSI which makes me assume it is probably a 2000 PSI pump but I can't find anything on GPM. I am trying to figure out if it has the power & speed to run a 3 point hitch log splitter that I am eyeing.
Thanks!
   / Mitsubishi MT250D Hydraulic question #2
You tractor can support 16 GPM at 2300 psi, but the attachment flow is probably about 8 GPM.
An equivalent Kubota would have about 6 to 8 GPM.
As far a funning a log splitter, answer is yes.
GPM determine the speed and pressure determine the force.
So if using a 4 in cyl with a pressure of 2300, the force would be about 14T.
If you wanted more speed, Prince makes an LSR log splitter valve that will use 4 GPM and make that into a 25 GPM log splitter.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
