mitsubishi mt20d
   / mitsubishi mt20d #1
4wheelerman
northwest missouri
mitsubishi mt20d
hey was just woundering what you guys thought of the mt20d.Does anyone know what this would come close to in a us model.
   / mitsubishi mt20d #2
looks like a mt250d. but it could be different. looks like a newer design.
   / mitsubishi mt20d #3
The only thing a MT250D and MT20D share in common is the Mitsubishi name
buck
   / mitsubishi mt20d
efc what would you say is closest us match to the mt20d. thanks jack
   / mitsubishi mt20d #5
you are out of luck dude.there may be no exact match.however some parts may match other tractors.my mitsu has a 4 cyl engine and uses a fram ph 3950 oil filter.
   / mitsubishi mt20d
so mit how do you like your mitsubishi mt250.i used to have a little 2wd kubota l1500 and thats what got me hooked on the compacts then i got this mitsubishi and it went from a 15hp tractor to a 23.5hp 4wd tractor and this thing is awsome it cracks off with the first piston up with out the use of the glow plugs it runs forever on a tank of fuel.i also never had a loader on my old kubota that is as handy as a pocket on a shirt.i cant pick up as much as i can with a full size loader but i can get in a lot more spots with it.well ill stop flappin my jaws and let someone else talk.but i have nothing but good to say about mitsubishi. jack
   / mitsubishi mt20d #7
i have a d1850. havent done too much with it. i just took out a big stump with it using the front bucket and a tow rope. the tractor once it gets going it has a lots of balls.i am having a problem with the glow indicator now so i took the dash off and am waiting for my new part to arrive this week.ordered a used one from kytp.com: The Best Search Links on the Net. i think i may need new glow plugs.it takes too long to pre heat and when it is ready the glow indicator gets so hot it was melting the dash. i tested my plugs and they all read the same i do not have a new one to compare it to.my meter seems to be a little off so i am not quite sure.they read 1.5ohm. but the meter when u short the leads reads .4ohm. so the plugs could be reading 1.1ohm instead of 1.89 ohm.they may be worn out.
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
