Mitsubishi MT18D starts but cuts out after a few seconds
   / Mitsubishi MT18D starts but cuts out after a few seconds #1
pdflat
MITSUBISHI MT18
Hopefully this is a simple fix. My Mitsubishi MT18D was running perfectly but suddenly died. It will now start, run for a few seconds, then dies. Could anyone let me know what to check, and where that part is on the engine, since I'm not exactly a mechanic.
Thanks
   / Mitsubishi MT18D starts but cuts out after a few seconds #2
Fuel filter, no idea where it is on you machine, but that's where I;d start.
Thanks. I've bled the fuel line, but it still stops after a few seconds. I recently put in an in-line filter, which may have something to do with it, although fuel is going through okay.
   / Mitsubishi MT18D starts but cuts out after a few seconds #4
3 possibilities come to mind.
Vent is plugged---try running with cap off.
Sucking air via fuel line---install new fuel lines and clamps.
Tank screen is plugged---blow air backwards into tank (blow from connection closest to injector pump)
Inline filter is not a problem (unless filled with crap)
Could also be injector lines that need bleeding (I often bleed at the injector)
Thanks for the above replies. I changed the dodgy fuel lines, clamps and in-line filter. The problem is still there. I now think it may be electrical. The problem often temporarily goes away when I fiddle with the battery connections. Also the 15A fuse for the dashboard lights keeps blowing. Does that suggest any obvious fault to anyone?
   / Mitsubishi MT18D starts but cuts out after a few seconds #6
Unplug one of the wires to the fuel cutoff switch. If this fixes it you need a new switch.
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
