Mitsubishi MT18D starts but cuts out after a few seconds
   / Mitsubishi MT18D starts but cuts out after a few seconds #1
pdflat
MITSUBISHI MT18
Hopefully this is a simple fix. My Mitsubishi MT18D was running perfectly but suddenly died. It will now start, run for a few seconds, then dies. Could anyone let me know what to check, and where that part is on the engine, since I'm not exactly a mechanic.
   / Mitsubishi MT18D starts but cuts out after a few seconds #2
Fuel filter, no idea where it is on you machine, but that's where I;d start.
Thanks. I've bled the fuel line, but it still stops after a few seconds. I recently put in an in-line filter, which may have something to do with it, although fuel is going through okay.
   / Mitsubishi MT18D starts but cuts out after a few seconds #4
3 possibilities come to mind.
Vent is plugged---try running with cap off.
Sucking air via fuel line---install new fuel lines and clamps.
Tank screen is plugged---blow air backwards into tank (blow from connection closest to injector pump)
Inline filter is not a problem (unless filled with crap)
Could also be injector lines that need bleeding (I often bleed at the injector)
Thanks for the above replies. I changed the dodgy fuel lines, clamps and in-line filter. The problem is still there. I now think it may be electrical. The problem often temporarily goes away when I fiddle with the battery connections. Also the 15A fuse for the dashboard lights keeps blowing. Does that suggest any obvious fault to anyone?
   / Mitsubishi MT18D starts but cuts out after a few seconds #6
Unplug one of the wires to the fuel cutoff switch. If this fixes it you need a new switch.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
Utility Trailer (A52377)
Utility Trailer...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
