Mitsubishi mt180d
   / Mitsubishi mt180d #1
Bronco Bobby
Hemet CA
Mitsubishi MT180
Hello all, I have a Mitsubishi that has the added front loader bucket. I spring a leak on one of the hoses that goes to the bucket and parked it for a couple months. Finally getting around to replacing the hose, I installed the new hose and started the tractor. The loader did not operate. I then foolishly attempted to bleed air at the top hose fitting. Fast forward...I realized that all of the fluid had leaked from the transmission/hydraulic system as it sat for two months. Now I have cleaned the hydraulic screen, replaced the fluid and have the front bucket working, however now the 3 point hitch will not lift. I have never had a problem with this in the past. Did I deadhead the pump? why would the bucket work, but not the 3 point hitch?
   / Mitsubishi mt180d #2
Well you have proven the pump is OK.
Probably some air in the 3 pt cylinder and air compresses while oil wont.
You somehow need to bleed out that air or find a way to prime the 3 pt circuit.
   / Mitsubishi mt180d
Yea it seems you are probably right, just not sure how to go about that. Didn't get to work on it over the last weekend. I am going to try this weekend.
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
