Buying Advice Mitsubishi MT1401D specifications
   / Mitsubishi MT1401D specifications #1
guyc1
Belgium
Yanmar 2310
I'm looking for a tractor and found a Mitsubishi MT1401D. The seller told me it's a K3B-engine with 18hp but I want to be sure before buying it.
If someone knows the specifications from the tractor and especially the engine (type, power (engine, not PTO), ci ...) it would be great.
   / Mitsubishi MT1401D specifications #2
Thanks for your reply.
Tractordata.com told me the first 2 digits are the engine-power. So the PTO-power should be less.
The problem is that I want to use a flail-mower and do some plowing. 14hp is to little, I think, but 18hp should be enough.
I see you've got a Mitsubishi. Are you satisfied with it? Do you find 'easily' parts for it?
   / Mitsubishi MT1401D specifications #4
I only recently got my Mitsu, and as usual with used equip it had a few probs. Needed a ign switch, a seat, and the biggie was the front axle seals were leaking BAD! Found the sw and seat quickly, but couldnt find the sizes of the seals. Tore into it and got the numbers off the seals when apart and then quickly found them using google. The real scare was when on re-installing I managed to crack/break the left side cast iron gear case - stupid mistake!:eek::eek: I thought I was screwed!
But again, back to google and on the 3rd call to (Front Axle) I lucked out and they had the part. (I was told that part broke pretty easily and were sold as soon as they got one in) Mitsu parts arent nearly as available as say, Yanmar but there are a few, you will just have to do a search. I recall running across one that was listed as in the UK (I think)
Well, I hope you won't have such a big problem anymore and that your Mitsu will do the job.
   / Mitsubishi MT1401D specifications #6
My S-470 Buck has a K3 B engine. That is cast on the side of the injection pump.
I bought a Yanmar 2310 (1980-1981). It's got 26hp so I don't have to worry about that issue. The engine is just running fine and fluids and filters are changed. The muffler is completely rusted and need to be replaced.
   / Mitsubishi MT1401D specifications #8
How is the Yanmar running these days? Need a manual for it?
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
2014 Deere 304K (A50120)
2014 Deere 304K...
Xtreme XR1045 (A50120)
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
