Mitsubishi MT 2001
   / Mitsubishi MT 2001 #1
landbeas1
Camden,SC, United States
Mitsubishi MT 2001
I bought my sisters MT 2001 and not sure about the pto. When I have the bush hog running if I push the clutch down the tractor trys to keep going until the hog stops. Could someone tell me what I might be doing wrong or is something wrong with the tractor. I dont have a manual to use to help me with it.
Landbeas1
   / Mitsubishi MT 2001 #2
Welcome to TractorByNet!
I moved your thread to the Mitsubishi/Satoh forum. :)
   / Mitsubishi MT 2001 #3
A lot of these did not have a built in overrunning clutch. Some of the older US tractors are like that also. My Mitsubishi 1450 does the same thing. You can buy an external overrunning clutch at Tractor Supply which may necessitate shortening your implement pto shaft. Or do like I do and knock the tranny out of gear when you get to the fence.
Thanks i will check that out. I dont use the hoh much so hope this will help
2018 Generac S/A Towable Light Tower (A52377)
2018 Generac S/A...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
