Mitsubishi K43 diesel engine seial number Location
   / Mitsubishi K43 diesel engine seial number Location #1
Bjarn
BC
Komatsu PC50uum-2
I have a Mitsubishi K4E diesel engine in my excavator. On the top right hand side of the block in casting letters it says "K4E 1.415L". It also has a "0618N" casting number on the block beside the oil filter.
I need a head gasket for it. Does anyone know where the engine serial number it located on the K4-series diesel.
   / Mitsubishi K43 diesel engine seial number Location #2
My K4E has a metal tag attached to the top of the valve cover.
No metal tab on mine. The motor is still in the machine so it is hard to see anything. If I knew where to look it would be a great help.
I know I can buy any K4E series head gasket for it, but they vary in thickness depending on what application the motor is used for (generator, excavator, pump, etc.). That difference in thickness could affect the performance of the motor if the wrong one is chosen.
   / Mitsubishi K43 diesel engine seial number Location #4
Do you have a manual for the engine? It should give you the location in there. What machine is the engine in? A dealer may be able to help The "1.415L" is the engine displacement = 1.415 liters. The serial number would be a stamped number on a flat surface, not a cast in number. I won't be at my machine for a week, so I can't verify where it is on the block.
No manual. The dealer asked the same questions you did. The engine in this machine is a replacement motor. The K4E series Mitsubishi motor was used by many different equipment manufacturers, each having their own parts code numbers for the same parts (Eg: Caterpillar use the Mitsubishi motors but you need the Cat number) that's why the stamped serial number is needed for the proper application. This stamped number is what I am looking for but because of the very cramped space it is difficult to find, hoping someone knows where to look.
   / Mitsubishi K43 diesel engine seial number Location #6
I have the OEM Mitsubishi manual. I'll check it tonight. I believe it will also have the OEM head gasket p/n for the excavator engine. No part numbers.
Thank you, I found it
By the way, the motor was painted after the number was stamped. Even knowing where it was, it was difficult to see. Again, I appreciate your assistance.
2007 Chevrolet Tahoe 4x4 SUV (A51694)
2007 Chevrolet...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2024 KMC 7406 (A53084)
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
Sterling 9500 (A53473)
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
