Mitsubishi D3850 help
   / Mitsubishi D3850 help #1
elranchito
Huntsville, AL
1939 John Deere L, Mitsubishi D1850
I am trying to locate engine parts for a Mitsubishi D3850. The cam shaft sheered off and damaged all the gears and bearings below. Have searched everywhere but seem to be running out of options. It has a 4DQ3 motor with turbo. Is this motor in any other tractors? I have been impressed with the extensive knowledge base on this forum. I have enjoyed reading and learning over the last several months and hope someone might have some information that I can follow-up on. Thank you.
Thanks Oliver. I have been in touch with one of these but I will contact the other one. Thanks for the information.
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A52377)
2006 Crimson...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
