Mitsubishi D2350FD - CHG bulb - Service Indicator?
   / Mitsubishi D2350FD - CHG bulb - Service Indicator? #1
sharkblood
Isaccea, Romania
Mitsubishi D2350 FD
Hello,
after almost 6 years owning it, noticed this orange light on the tractor meter. :eek:
It is labeled CHG and sits next to the OIL light.
Is this some kind of service indicator? If yes, how can I reset it?
It's wired up to that "control unit" under the steering wheel, on the left side.
The other question would be if there's any chance to fix the tach meter. As of now, revs are shown, but the counter doesn't work anymore.
I wanted to dismantle the gauge but there seems to be no way to do that without leaving serious traces.
Ooopsss, silly me. That CHG light must be there for the electrical charging.
But how about fixing the tach meter?
   / Mitsubishi D2350FD - CHG bulb - Service Indicator? #3
I have no idea how to repair your factory meter but I would suggest installing an accessory hour meter. They are very inexpensive and easy to install. It would allow you to track any future run hours and that time can always be added to what the factory meter is showing for total run time.
Are there good ones for diesel engines?
   / Mitsubishi D2350FD - CHG bulb - Service Indicator? #5
I just bought a Mitsubishi D2350FD 4x4 guy says it has low oil pressure even after a new oil pump so my question is there another engine out there besides another Mitsubishi diesel that will inter change with zero problems??
   / Mitsubishi D2350FD - CHG bulb - Service Indicator? #6
It would be simpler to overhaul it & have the crank turned & installing undersize bearings. Then you know you have good engine.
Sterling 9500 (A55315)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2009 INTERNATIONAL RF027 DAY CAB (A56138)
2009 INTERNATIONAL...
Cushman Cart (A55853)
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
