3-Point Hitch Mitsubishi D2350 Hydraulic Filter Location
   / Mitsubishi D2350 Hydraulic Filter Location #1
lacroix
i've got a D2350...used it to cut grass, parked overnight, 3 point hitch will not lift the next morning...it has a front bucket that does still work
i've read quite a few threads here and other places that say to check the hydraulic filter...where is the hydraulic filter located on my tractor and what does it look like
any help is appreciated
   / Mitsubishi D2350 Hydraulic Filter Location #2
It's located down under your right heel on the side of the transmission case as you're sitting on the tractor. Looks like a plate, with either two or three bolts holding it in.
thanks a lot
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
