Mitsubishi D1600FD Lift Arms wont go wide enough
   / Mitsubishi D1600FD Lift Arms wont go wide enough #1
MountainManMike
Gatesville, Tx
Ford 851, Mitsubishi D1600FD
Need to get my lift arms to go wider (for some Cat1 implements that I cannot turn the pins to the inside). Found some longer arms with offset at Hoye tractor but I'm not sure if they would work. Anyone have experience with this issue?
Thanks, Mike
   / Mitsubishi D1600FD Lift Arms wont go wide enough #2
Hello mike, I have no experience with that tractor and don't know if it's possible, if they make wheel extenders you could move your wheels wider and give you more clearance between your wheels and maybe your three point arm will swing wider and also give you better stability.
   / Mitsubishi D1600FD Lift Arms wont go wide enough #3
Thanks, Mike
Sometimes you can switch sides with the rear tires to take advantage of the dish on the rim? Ken Sweet
   / Mitsubishi D1600FD Lift Arms wont go wide enough #4
i used a quick hitch and put the pins facing inward to clear tire chains on my old kubota.
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
TUBELINE TL50LSV LOT IDENTIFIER 107 (A53084)
TUBELINE TL50LSV...
