Mitsubishi d1550fd Medium drive not working
   / Mitsubishi d1550fd Medium drive not working #1
daddio1000
Tulsa, ok
Mitsubishi F1850FD
i just got a used Mitsubishi D1550fd tractor and the medium range drive is not working. The low will engage but has to be pushed further forward than the ball set point. The high gear range works also at its normal set position. Any suggestions please?:confused2:
   / Mitsubishi d1550fd Medium drive not working #2
Take the top cover off the transmission case and look inside. You may have to drain the oil to see the range gear set. You should be able to visually see what is going on from the top though. Put the main gear shift lever in neutral, take the bolts out that go around the perimeter of the cover. If it has been a long time since the cover has been removed, you will probably have to tap and gently pry to get the cover to lift off.
   / Mitsubishi d1550fd Medium drive not working #3
I will attempt to attach a page from my parts book that shows a picture of the shifter parts. Hope this helps. Sorry it is upside down but you can click on view and rotate the document.
Thank you guys for the information and advice. I will take a look at it when I get the chance in a couple of months and the weather warms up. I will keep you up on my findings.
Bill
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
John Deere (A50322)
John Deere (A50322)
2019 Ford F-150 Crew Cab 4X4 Pickup Truck (A53422)
2019 Ford F-150...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
