Mitsubishi D1550 PTO Speeds
   / Mitsubishi D1550 PTO Speeds #1
stevesmit
swaffham Norfolk UK
mitsubishi compact
HI
I have have a Mitsubishi D1550 tractor, it has a 3 cylinder engine 6Fwd 2Rev transmision.
The PTO has 3 speeds can any some one advise what the speed ranges are, as I only have an RPM clock. How many PTO turns per engine rev is each gear?
I wish I still had a hand tach.
Oh by the way how many horses should be generated by my engine?
   / Mitsubishi D1550 PTO Speeds #2
Can't help you on the pto speeds, other than to say 1st is your 540 at the rpm that should be marked on your tach. Horsepower would be rated15.5 at the pto, and 19 at the flywheel.
Ken
   / Mitsubishi D1550 PTO Speeds #3
Ken
Thanks I didn't see any marking on the tach besided the actual RPM
   / Mitsubishi D1550 PTO Speeds #5
the three pto speeds are as follows
1=517 rpm
2=762 rpm
3=1250 rpm
1st being all the way on the bottom (or forward) and 3rd at the top or towards the rear of the machine,
Hi Satoh S2300
Thanks for the info, I have another question.
What engine RPM would give these pto RPMs
   / Mitsubishi D1550 PTO Speeds #7
sorry, at full throttle, or 2900 rpm
Cheers
Thankyou very much.
who would you suggest I contact for a manual?
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
Dump Box Truck Body (A52377)
Dump Box Truck...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
