Mitsubishi D1500
   / Mitsubishi D1500 #1
txbowler
Palestine, Texas
Mitsubishi D1500
Replaced battery, now it won't start. Can hear the clicking sound, but only occasionally. Otherwise, nothing. What should I look for??
   / Mitsubishi D1500 #2
Sounds like you've got a bad electrical connection somewhere, probably in the battery terminal end or where the ground ties into the frame. Once you've cleaned and re tightened them, try shorting across the solenoid with a screwdriver. If it cranks that way, then you've got some kind of problem between the switch and the solenoid.
   / Mitsubishi D1500
Have power, everything lights up when switch is turned on, just no turning over, not even a clicking sound. I guess replacing the switch would be the least expensive to try. Ground off battery is tight, all connections to solenoid are tight.
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A52472)
2021 QUALITY...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
1266 (A50490)
1266 (A50490)
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
