Mitsubishi D1450
/ Mitsubishi D1450 #1
backporchtom
Braselton, GA
Mitsubishi D1450, 1972 Power King, 2009 Kioti CK 35
I am looking for any information regarding a Mitsubishi tractor manufactured in Japan but sold in the U.S (known as gray tractors). It is a Mitsubishi D1450 2 wheel drive tractor. It was a gift from my mom who was the second owner. Specifically, I need a manual that explains how the tractor operates and how to maintain it. It also has a 18 spline PTO that is broke because someone used a steel bolt instead of a shear pin. The PTO replacement is what I need to start with. Would prefer a six spline PTO if possible. It would also be nice to know if any Mitsubishi compact tractors in the USA are a close parallel to the D1450. I know tractorspeak as I own a PowerKing (currently restoring) and a Kioti CK35. If anyone out there can help get me off to a correct start, I would appreciate it.
Sincerely, Backporchtom, Braselton, GA
/ Mitsubishi D1450 #2
I have owned one since 1996. The 373 is almost identical except for the pto. 373 has standard 6 spline. The bolt hole in your pto is not for a sheer pin because the shaft is splined. It is only to hold the yoke on. You can get parts and manuals at Valley Power or Japanese Tractor Repair Dixon, IL. The manuals I have cover the 373 and 470.
/ Mitsubishi D1450
Thanks Oliver for the information. Mr. Shaffer in Dixon, IL states that the 18 spline pto can be replaced by a 6 spline PTO and the existing cover will fit. Would appreciate you advise and also exactly how the broken PTO is removed and a little what is involved. Thanks, Backporchtom
/ Mitsubishi D1450 #4
Somehow I missed your reply. I haven't had to tear into mine so you'd better call Len for that. Either one of those can sell you the manuals.
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
Landhonor Livestock Chute w/ Scale (A66408)
Landhonor...
2022 EZ-GO ELITE...
New/Unused ATS Mini Excavator (A65583)
New/Unused ATS...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2022 EZ-GO ELITE...
