Mitsubishi 372 battery size
   / Mitsubishi 372 battery size #1
AlabamaNorm
Mitsubishi 372
I need a new battery for a Mitsubishi 372...anybody know which one I need ?
   / Mitsubishi 372 battery size #2
Can just measure the battery space to find one the correct physical size, then just get the one that size with the highest cca
   / Mitsubishi 372 battery size #5
Greg - I have the original batteries (dry charged) in stock or you can go to the local auto parts store and by a 22NF battery. It is a little taller than the original but works very well. Use a heavy rubber tie down strap instead of the battery holddown. We have parts and service for your tractor here in Roanoke. Call 1-800-609-5110. Bill
Thanks much- that's just what I needed. The old battery was marked 322NF which I couldn't find listed anywhere. I found a 22NF at the local TSC. I will keep your number should I need any Mitsubishi parts!
Is a front plastic grill available?
Thanks,
Greg
   / Mitsubishi 372 battery size #7
Well,
you’d need to pop the hood first….😬
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
Schulte SBW800 Rock Windrower (A55314)
Schulte SBW800...
Enmark Z Spray (A53316)
Enmark Z Spray...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
John Deere 5065E 2WD Tractor with Canopy (A55314)
John Deere 5065E...
