mitsubishi 300d hyd pump
   / mitsubishi 300d hyd pump #1
farmer4041
I have a mitsubishi 300d great little tractor but . I need a hyd pump for it anyone have any ideas where to find one. With out having to sale the farm to buy one thanks Happy farming gary
   / mitsubishi 300d hyd pump #2
The mitsu pumps are costly, you wont sell the farm but might need a morgage.
My mitsu has 2 pumps, the second being driven from the front crank pulley using the pulley to PTO Mitsu adaptor and a u-joint.
That might be something to consider as an alternative.
I did this for faster loader operation as the factory unit was real slow, factory unit now serves only for the 3-point lift.
Fortunately my loader incorporated a reservoir in one of the frame posts and it resulted in much less footage of hoses hanging around to get damaged.
If any are available, there are a couple of members that generally will chime in as they specialize in Mitsu parts.
Thanks thats a idea. I have a pto pump on the back that I use to run my 3 point hich backhoe. But I cant run my tiller that runs off the pto and and the pump at the same time. Yap the 300d has two pumps one that runs the power stearing and one that runs the main hyd. that both run off the same gear. one would be clock wise and one counter. someone has to make a pump for it. wonder if cubs or any of them do I think thay all run the mitsubishi motors. ok just thinking out loud. Gary
   / mitsubishi 300d hyd pump #4
I can usually provide an aftermarket pump for a lot less than the OEM one.
2019 Dodge Durango AWD SUV (A59231)
2019 Dodge Durango...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
16001 (A55853)
16001 (A55853)
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
