mitsubishi 2650d 4x4
   / mitsubishi 2650d 4x4 #1
jeannieido
jacksboro, tx
d2650fd
Any one have any dynamite? This 2650d hasnt been started for over 7 months now. We have replaced the glow plugs, the injectors and put new diesel in it, it still will not start. No black smoke. Today we took the throttle linkage off hoping maybe it was stuck in the kill position, no such luck. Any other suggestions??
   / mitsubishi 2650d 4x4 #2
I assume it was running fine and then sat for 7 months...... can't be much wrong with it. I would make sure you have a strong battery....cranking speed is important. Make sure you are getting fuel at the injectors- crack each fuel line and crank the engine over to make sure it is getting fuel at the injectors. Lastly, if you have access to a air compressor, remove the filler cap and stuff some rags around a blow gun. Pressurize the tank and crank it over....this goes a long way in helping a hard to prime system. I have had to do this several times through the years and suggested this to others here on TBN.....if it is a priming issue, this usually does the trick on forcing any air out and starting a steady flow through the pump and lines.
If this doesn't work, send me your address and I'll come take that piece of junk off your hands! I sold a 2650 to a friend about 10 years ago and regretted it since. I've been wanting another 4 cylinder Mitsubishi for a while :D
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
UNUSED WOLVERINE PFF2-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
