Tractor Sizing Mitsu MT 2000 D
   / Mitsu MT 2000 D #1
kc4knl
Does anyone out there know if this tractor can handle a King Kutter II 4 foot tiller? The tractor is a 3 cylinder rated at 25HP. PTO is rated (I think?) at around 21HP. The tiller is gear drive which adds weight to it. I've heard these are great tillers. thanks Mike:confused:
   / Mitsu MT 2000 D #2
I run a 4' behind my S-470 Satoh Buck. Rated at around 15 at the pto. Tractor and tiller both new in late 70's, still going strong.
   / Mitsu MT 2000 D
Thanks Oliver. I didn't know if I had too much tiller for the tractor. I do like both.
I'm new to this but learning. Mike
   / Mitsu MT 2000 D
Oliver, I tilled my garden Saturday and I can't say enough good about the new set up. My tractor and tiller are a perfect match. I can't understand why I waited as long as I did to get the King Kutter II. Thanks for your imput. Mike
   / Mitsu MT 2000 D #5
Welcome to TBN! I'm just one of many who contribute here. Have been helped many times by the others.
   / Mitsu MT 2000 D #6
I have a Mitsubishi MT 2000 has hydraulic pump problems . I found a MT 2201 with bad motor is it possible to change front end of MT 2000 put on backend of 2201 just wondering ? or would pump& cylinders on inside interchange ? Looks like it would interchange any comments welcome !! Thanks .
   / Mitsu MT 2000 D #7
I haven't looked a parts crossover but it is very likely the 2000 and 2201 use the same hydraulic pump. I am assuming this is an old style 2000 gear drive and not the new model hydrostat we are talking about since you are talking about swapping front/rear halves to a 2201 gear drive. The pump simply unbolts ( 4 bolts) from the back of the timing cover. A very simply fix. Swapping/or replacing anything but the pump is unnecessary. A new pump is available from a number of online Mitsubishi parts dealers and are often listed on ebay. A stock pump runs anywhere from $300-$500 depending on who you get it from. This guy http://www.tractorbynet.com/forums/mitsubishi-satoh/270451-mitsu-d2650fd-gettin-started-4.html describes how he replaced his stock 5GPM Mitsubishi pump with a larger 9GPM pump from NCW Tractor Parts for the same price.
What is wrong with your current pump?
   / Mitsu MT 2000 D #8
come too find out its not the pump its the cylinder inside that operates the 3 point my brother took out & then the wildfires burnt his shop up wiyh cylinder but tractor survived sitting on dirt spot thanks i'm just trying to get it going he give it to me & I haven't got it here to check yet
thanks Marv.
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2019 Infiniti QX60 SUV (A51694)
2019 Infiniti QX60...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
1840 (A51248)
1840 (A51248)
