Mitsu D1850 running problem
/ Mitsu D1850 running problem #1
4wheelfurry
Deep South Louisiana
2009 MF 1540 (sold) 2020 MF 1755M
Neighbor has a D1850 that will run great until the engine warms up, then it looses power. The engine will start and rev fine, is not using oil but when you put it under a load it will power out. Only does it when warmed up, it will not loose power if under a load when cold. Perliminary checks show everything visible are good. Any ideas?
/ Mitsu D1850 running problem #2
We need a little more information on what kind of preliminary checks you have done. My first thought is the fuel cap may not be venting as it should. By the time the engine gets warm there is a vacuum in the tank, holding back fuel delivery. Warm it up and open the cap. Let us know if it makes a difference.
Thanks folks, I meantioned the filter to him and he couldn't remember the last filter change. Never thought about the fuel cap. Really just wanted to know if there was anything common with mechanical parts. I appreciate the advice.
3Pt Disk (A66285)
3Pt Disk (A66285)
15 TON GRAIN BIN (A64280)
15 TON GRAIN BIN...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
UNUSED WOLVERINE TDB-11-72W 72" BUCKET (A64281)
UNUSED WOLVERINE...
