Misunderstanding Mid Mowers
   / Misunderstanding Mid Mowers #11
Just build a round house with no bushes, shrubs or trees, end of problem.
My neighbor bought a Cub with a RFM. He used it one year and now the RFM sits in the weeds. He has a MMM now and loves it.
murph
Hey Murph, ask your neighbor if I can have his RFM. I'll even come get it. :)
   / Misunderstanding Mid Mowers #13
daTeacha said:
You guys need to try out a Steiner with a FFM. That's front finish mower. It gives you all the advantages of driving a RFM in reverse except you can see what you're doing and not be acting like a character out of The Exorcist while doing it.
It's bad enough in the dry periods of the year mowing and having dust problems behind you with a RFM. But a mower out front is sure to stir up a cloud at times that you'l need to drive through.
   / Misunderstanding Mid Mowers #14
Yep that is actually a problem I get more often with eveb a MMM over a RFM, if there is any wind I'm sure to eat and wear some dust, dry grass clippings, etc. I only really suffer though when I mow part of what used to be old horse pasture and had a mix of bermuda grass and annual rye growing on it, so there is a lot of dead grass still to kick up. Hopefully in a year or two that will be better. Something in that dead grass, either the bermuda or the rye irritates my skin and causes welts to break out :(
I guess if all you are mowing is a well established lawn that shouldn't be much of a problem.
Inside corners are the biggest pain, with a MMM you just can't get it all, with a rear mower you can at least back into it.
   / Misunderstanding Mid Mowers #15
My LandPride RFM came with hi-lift blades from the factory and those things create a tremendous vacuum under the deck which translates to an incomprehensible amount of dust. I ordered a set of lo-lifts and it was a night and day difference. They also make a medium lift set but I haven't tried them.
John
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A51039)
2022 Quick Attach...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
71056 (A49346)
71056 (A49346)
