Allen2
Bronze Member
- Joined
- Mar 16, 2005
- Messages
- 60
- Location
- Westmoreland County, SW PA
- Tractor
- 2025 Summit TX25H w/grapple & forks, 2005 Kubota BX23 w/MMM, 1986 Simplicity Sunstar w/MMM & Blade
I've had my BX23 since March. Normally I pull it into the garage with the left side facing a wall. The last time I was out I backed it in, for no particular reason. As I am working around the garage on Saturday, I notice that the front wheel on the left only has 3 bolts instead of 4. I didn't normally see this wheel because it was facing the wall. Luckily the insides of the wheels haven't gotten that dirty yet. Looking closer at the hole in the wheel, it still has the orange paint around it. I am pretty sure it never had a wheel bolt in it. My dealer is over 100 miles away. Talked to them this morning and they are sending one out to me. Shortly after I got the BX23, I discovered one of those hairpin type clips missing from the pin through one of the backhoe controls. It didn't take long for the pin to work its way back and let the handle come loose. The dealer sent me the clip for that too. I am going to have to make a closer inspection of this tractor when I get time to make sure nothing else is missing or ready to fall off. As a general heads-up to those of you with new tractors, check your wheel bolts to make sure you have them all and that they are tightened properly.
Allen2
Allen2
