mirror on tractor
/ mirror on tractor #1
mkey
Oklahoma
Deere 5105 / Ford 1100 / 756 IH Farmall / Kubota 2501 LA525 BH77 / Massey 1E.25
hello everyone. After spending some time working with my tractor I usually have a stiff neck afterwards from looking behind me while backing. I was wondering if anyone has installed a mirror on their tractor to help with working in reverse? I have seen mirrors on cab models but none on an open tractor. I want to know if any aftermarket company makes mirrors for this purpose. If not I would like to attach a bracket midway on the ROPS extended out over the operator station with a rectangular mirror. Things that look good on paper may not work in the real world. Thanks!
/ mirror on tractor #2
mkey, sounds doable....so long as the bracket extended out over the operator is a canopy!! /w3tcompact/icons/laugh.gif Take your oportunities when they arise!/w3tcompact/icons/wink.gif
/ mirror on tractor
Thanks Scruffy! That is a great idea! That will take care of the mounting and provide comfort. As I think more about it I will need two mirrors, one in the front of the operator station and one behind and hopefully I can get proper angle to see the implement's operation. I am thinking about two rearviews like from a bus? I will start on this and hope it helps. Now to find a canopy! Thanks all for the great information on this board!
/ mirror on tractor #4
mkey, take a look at 'Tractor Canopies' in this forum. Bird posts about the one he bought from:
Wells Ag Company
617 S. McLennan Drive
Elm Mott, TX 76640
(254) 829-2822
NOTE: Bird said the manufacturer (Wells) only sells to dealers, so you would have to have your dealer contact them.
Sounded pretty good, others have also posted about their canopies. don't know of anyone who made a successful purchase from the 'Bernie' character though. Good info in the thread though. good luck with your 'mirror bracket'!
<P ID="edit"><FONT SIZE=-1>Edited by scruffy on 09/15/01 08:31 PM (server time).</FONT></P>
/ mirror on tractor #5
Tried a mirror on my canape and on the FEL support arms - the vibration was was so bad that they were useless.
TC33D
/ mirror on tractor #7
MarkV, I put the mirror on my canopy primarily for use when I drive the tractor on the road. I want to know whether anything is coming behind me without constantly turning to look back. It serves that purpose, but it's a round, convex or wide angle mirror that lets me see if I'm actually mowing behind me, but not nearly as well as I'd like. I'm going to be looking for a different mirror to replace the one I now have. However, I do not have a problem with vibration on my canopy (and I actually suspected that I would have before I put the mirror on there). In a few minutes I'm going to post a picture in the photo forum in which you might be able to see the mirror on the right front of the canopy.
Bird
/ mirror on tractor #8
I have wanted to go to a wrecking yard and get a winshied mount rear view mirror to add to my canopy for driving on the road. They have a metal part that glues on. I'll bolt instead of glue, however.
I built a canopy like a wells, but used thicker (0.125") aluminum instead of the 0.060 used by wells. The cost of the metal was about $210.
A canopy is an easy project if you have a welder. No critical tolerances, no moving parts.
/ mirror on tractor #9
I mounted a mirror on my TC 21 D, but I'm not quite satisfied with the results so far. May need more engineering!!!!
/ mirror on tractor #10
When I originally bought a rear view mirror to put on my canopy, I looked at K-mart and Wal-mart without finding anything, then could only find that 5" diameter convex mirror at AutoZone, so I've been using it, but yesterday I was in a Tractor Supply Co. store and found a 5" x 7" flat mirror ($6.99) that I think will be much better, so I installed it a few minutes ago and made a picture of it.
/ mirror on tractor #11
Bird, I was thinking more on a bus mirror didnt know if it would be to big but man that setup looks great.
__________________________________________________
Take care, Jim
2001 B7500 HST 302 Fel R4 Tires, Befco BRB60
Semper Fidelis
/ mirror on tractor #12
I found a mirror that is intended to be an extention mirror to strap to any perminent vehicle mirror if needed for occasional wide tows. It has heavy rubber straps that I used to strap it to the top of my verticle FEL support frames. I just use it for when I take the tractor on the road & then I can take it off other than that. One silly thing on my part, I left it on this weekend (=lazy), & knocked it off with when branch from a brush pile flipped and hit it & then ran over it! For the land clearing that I am doing, that is why it was nice that I could (SHOULD) take it off. I don't have a picture of it yet. I got mine at Quality Farm N Fleet but I imagine that they are available anywhere that has trailer towing accessories. I need to p/u another one - I think that they are about $12-15...
Deutz D3006 Tractor (A62613)
Deutz D3006...
Tires and Rims (A65640)
Tires and Rims...
(4) Tractor Wheel Weights (A65640)
(4) Tractor Wheel...
30x57 Welding Table (A65640)
30x57 Welding...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
