Minsk Tractor Works has officially introduced 466 hp straight frame tractor MTZ 4522
   / Minsk Tractor Works has officially introduced 466 hp straight frame tractor MTZ 4522 #1
McManaman
Toronto, Ontario
MTZ Kirovets K744
MTZ BELARUS 4522 is one of world痴 largest fixed frame tractors.
It痴 a general purpose tractor, drawbar category 8 with 4x4 wheel formula.
Designed to perform energy-intensive agricultural operations in towing and trailer driving modes.
Maximum output: 466hp, 342,7 kW
Engine: CATERPILLAR C13 Tier 3; 6-Cylinder, turbocharged and charge air cooling
Torque capacity, Нキm2: 2048
Transmission: Power Shift; FWD/BWD-16/8 (3,4km/h ... 38km/h / 2,9km/h ... 16km/h);
Front PTO: 1000 rpm,
Rear PTO : 1000/1450 rpm
Hydraulics:
Load-carrying capacity - Front 5,500 kg (12,100 lb) / Back 11,500 (25,300 lb);
Full scale pressure 21,5 MPa;
Pump capacity at nominal speed of diesel crankshaft, l/min, minimum 200 L/min (53 gpm);
Hydraulics tank capacity 175 L (46 gpm)
General:
Length/Width/Height mm - 7100/3020/3630 mm
Maximum weight 20,000 kg (44,000 lb)
Tyres: front - 600/70R34 back - 710/75R42
Fuel tank capacity 650 L (171 gal)
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
19200 (A50324)
19200 (A50324)
