minor leak in rear transmission/differential
   / minor leak in rear transmission/differential #1
wschreib
latham, New York
Ford f1620
I have noticed a very small leak of hydralic oil from the rear of my tractor. I lose about 1 teaspoon of hydrolic oil in a weeks time and cannot find where it is coming from. I have ordered a "stop leak" product
which is supposed to act a s stop leak in a hydrolic system. I was talking to my local New Holland dealer and he mentioned that I should NOT put any additive in the system as it could plug up various screening and make the problem worse.
Which is a correct action to take as If I have the NH dealer replace the seal it will be VERY expensive. Is that small leakage something to ignore until it gets worse???
Thanks;
wschreib
   / minor leak in rear transmission/differential #2
i would NOT reccomend a stop leak.
I WOULD clean up the area so you can see where the oil is dripping from. then address that issue.
what machine?
   / minor leak in rear transmission/differential #3
+1 no additive.
1 teaspoon a week? I would let it be. in a few months or a year you might have to top it off. lol But I can understand wanting to keep your machine tip top with no leaks.
if you can clean up the area really well you should be able to tell where it is coming from. Maybe clean it up and then not use it for a few days/ a week so the oil will be fresh with no dust sticking to it. might make it easier to ID the source.
   / minor leak in rear transmission/differential #4
my f350 leaks a teaspoon of atf a week. i plan on letting it keep doing that. lets me use up that scrap cardboard from the dog food boxes the cans come in...
205028 (A52706)
205028 (A52706)
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
