TMAC
Well, last Saturday with only 3 hours on my tractor I noticed a small puddle of hydraulic fluid about the size of a silver dollar on the concrete floor. Traced it back to where it was coming from and it appears to be seeping out from underneath the FEL joystick, specifically from one of the lines connecting to the joystick block. My guess is that maybe an O-ring on that line is pinched and not sealing properly? I've been continuously checking the fluid level and everything seems OK so far. I have some fluid on standby just in case to keep it filled but wanted to know if any one has any suggestion or have dealt with the same problem? Maybe refer me to a previous thread.
Since then yesterday I bush hogged some but didn't use the FEL that much in regards to the slow leak. Still not a lot of leaking just the next day I notice a few drips on the floor.
I called the dealer Saturday as soon as I noticed and he said check it out to see if it needed tightened and call back if not. So I tried to get a wrench in there but without unscrewing the other lines I cant get a wrench on it. So here I am with 7 hours on my tractor and still a little leak. I hope it's only a minor fix. Any suggestions. Do I just need to get it back to the dealer right away or make them come out and take a look?/forums/images/graemlins/confused.gif
